  • Replies 14.2k
acts of kindness often go unnoticed in the world, especially on SAU. I want to give a massive thanks to SLEEPER85, aka Christian, who borrowed my coilpacks and dropped them off with a bottle of Johnny Walker black! Didn't expect to get anything and didnt ask, so if you ever lend or buy etc. something from him, hes definately a trustworthy forum user :)
Yeah. Few minutes per side for the castor easy and while you have the shock/spring out the camber arms right there.
just remember when you do install the adjustable items, to set them to the same length as the stock items. then you dont need to worry immediately about the alignment (ie it will be alright to drive to have a wheelie done on it)
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
theyre what... 8kg front 6kg rear? that isnt harsh norm. double digits is getting a bit painful. 8/6 is livable. my cusco's are 8/6, and theyre easily streetable. even with the dampers cranked up. whos told you theyre "probably" going to be too stiff?
from memory, luke (enr034) had 10kg springs on his cuscos, and that was beautiful to drive.
or... just double, triple, quadruple your budget and get pss9's or something similiar.
and just for fun, ask nightcrawler about his 'well thought out' suspension setup on the r34. that was f**king horrible if i may say so myself. bumpiest car ive ever been in.
as for installation... hardest part about fitting coils is setting the height. but thats more fiddling about than anything. actually fitting them though, im sure theres a lot of people on here that would be able to give you a hand. id do it, but you live on the other side of the world.
Edited by scandyflick
I'd have to disagree Dave....8/6 is beautiful......double digits no good for Adelaide.
A slight ripple on a bend with double digits and you come unstuck or a slight ripple at the end of a straight and your brakes lock up your wheels.
If worried about body roll, stiff shocks are not the answer.
Ive got 10f/8r. I was told to get this by Ryan because the Skyline is heavier than a Silvia, 180 etc.
On the topic of suspension, I had a hideous knocking sound in the front left, pulled it apart today and found the upper arm bushes need replacing. Recommendations/experiences on what bushes to use?
Saw that with general searching and creating a topic:
http://www.skylinesaustralia.com/forums/in...t&p=5186278
Although he did say that it's only not so great if it's a daily driver, which in my case it is not.
Probably won't fit the coilovers for a bit now (might still buy them as they're on special), but at least going to do the front castor rods ASAP. I'll speak to you about it on Wednesday week.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
    • Hey all, Noticed I have a hole on top of which im guessing is my transfer case/gearbox. I can see it from the middle of my firewall looking down. S1 R33 gtr Any advice or can pinpoint what this is/caused this?
