  • Replies 14.2k
Car is booked into Walker Chassis for July :blink:
Full weld in cage, Heaps of bars, strut tower bracing, the whole lot ;)
Got my welder mate coming down in the next couple of weeks to do seam welding, drop tank mounts and covering up the backseat from the boot ;)
looking at doing tarmac rally at any stage in the future luke? if so i advise that you get the sill bars done now, otherwise they're a flamin mongrel to get in later on. thats why mine's getting them now and when i need the additional bracing to comply with tarmac rally regulations, its partially done
yep sure is ;) one of the first things i did to it, just gotta have the cooler piped up, boost turned up and a nisstune board and im basically done.... for now
And you said you'd leave it standard! :blink:
Cheers mate, I'll add that to the list. Lance was also telling me about A-pillars bars if i should get them or not, he was saying it becomes a bitch to get in and out of the car tho.
Got any pics what the sill bars are?
Damm ppl posting before i hit reply, this msg is for matty t.
Edited by Luke_ENR34
please sir tell me more
the sill bars are essentially a bar that runs along the floor pan front to rear..............basically going to protect from random trees that may jump out in front of you. i'll try and find a diagram in the CAMS handbook
Hmmm wheel swap maybe :(
Don't swap to another of the 'emotion' series man - The XD9's suit your car to a T. Unless your going some like TEs - LMGT4s - or vlk GT-C's or something it won't look half as good as it does now!
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
