  • Replies 14.2k
Car is booked into Walker Chassis for July :blink:
Full weld in cage, Heaps of bars, strut tower bracing, the whole lot ;)
Got my welder mate coming down in the next couple of weeks to do seam welding, drop tank mounts and covering up the backseat from the boot ;)
looking at doing tarmac rally at any stage in the future luke? if so i advise that you get the sill bars done now, otherwise they're a flamin mongrel to get in later on. thats why mine's getting them now and when i need the additional bracing to comply with tarmac rally regulations, its partially done
yep sure is ;) one of the first things i did to it, just gotta have the cooler piped up, boost turned up and a nisstune board and im basically done.... for now
And you said you'd leave it standard! :blink:
Cheers mate, I'll add that to the list. Lance was also telling me about A-pillars bars if i should get them or not, he was saying it becomes a bitch to get in and out of the car tho.
Got any pics what the sill bars are?
Damm ppl posting before i hit reply, this msg is for matty t.
Edited by Luke_ENR34
please sir tell me more
the sill bars are essentially a bar that runs along the floor pan front to rear..............basically going to protect from random trees that may jump out in front of you. i'll try and find a diagram in the CAMS handbook
Hmmm wheel swap maybe :(
Don't swap to another of the 'emotion' series man - The XD9's suit your car to a T. Unless your going some like TEs - LMGT4s - or vlk GT-C's or something it won't look half as good as it does now!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
