  • Replies 14.2k
Did they inform you of the likely number of runs you'd get for the day? I would have thought they'd give you some idea how many runs you'd get (like track days). I know the competitors who paid something like $190 on Saturday only got 6 runs.
I'm guessing too that the $90 included the $25 day licence?
Saturday was funny. Some guy in a 180B did his burnout at the warm up area in preparation for his first timed run, and all I smelt was clutch. Poor guy couldn't get up the first section to the first turn. Rolled down the high backwards and failed trying again. Surely, he must have known his clutch was gone before he entered on the day. And he blew $190 odd. At least you made it up the hill to the finish line 5 times for $90. :P
nope, they didnt tell us what to expect. they did tell us they had over 100 particpants, from memory, somewhere around the 110 mark or more, when we were led to believe the max was 75.
and yes, the $90 included the day licence. even then, $65 for under 4 minutes of track time*? yeah, f**k that.
*im not counting time at the warm up pad or any of that as track time.
Edited by scandyflick
turns out 'collingrove hill climb' is sccsa speak for 'shit value for money'.
$90 for 4 runs up the hill.
i got a 5th because i told a little white lie to the official.
i dont think ill bother with collingrove again.
Skids were fun though :P
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
