Just got back from Melbourne. Left Adelaide at 4:10Pm yesturday arrived in melb at 5:30ish melb time. Picked up a 280rwkw supra with a mate and drove it back.
First road trip. Wasn't to bad :happy:
I like the trip between Adelaide/Melbourne - its not too long.
It was epicly fun driving back in the GTR... and kind of not at the same time(stiff suspension and loud exhaust with windows down made the right ear feel a bit funny after awhile), and surprising not too bad on the wallet - less than 2 tanks of fuel.
  • Replies 14.2k
i did adelaide to canbera in a stiff as coilover swift with no a/c in 40 degree heat. we were both burnt like lobsters on arrival. went through about 10 litres of water each.
but you gota look at it as an advernture :happy: and country people are funny when they see a modded car
Edited by Inline 6
On the weekend I drove to and from bendigo, VIC in an R33 with coilovers and 300~rwkw and only wet through roughly 4 tanks of fuel including driving around bendigo and heathcote,
I wasn't a problem at all.
SOO my horns dont work now
press the horn button and all i get is clicking in the engine bay from the relay
ive replaced all the fuses to no success
so this would indicate that the horn has been shorted out
correct me!
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
