  • Replies 14.2k
noticed the other day that my rb25det has a little oil in the coolant, not enough to change the color of the coolant but i can notice it when its in a puddle on the ground.
It seems to have lost abit of power from when i bought ( 2weeks ago), it does have a coolant leak from the block ( not was whats the parts called but ordered a replace from nissan, 3 weeks away, also ordered a coolant temp sensor as it wont start first time without pumping the accelerator.
Car doesnt show no signs of over heating, just a slight bit of oil in coolant and loss of power?
I wouldn't drive it if I were you.
This problem gets worse, not better and it's only a matter of time before the reverse (much worse) happens, if it hasn't already, ie. water in oil.
Sounds like a track between water jacket and oil gallery.
huh
if coolant is leaking from the gasket out your head running down the side of you block how is oil going to find its way into you radiator
yeah after re-reading it a few time i finally saw my errors :merli: brain was faster than my typing
haha, cause coolant already lives in the radiator bud.
I think you meant oil in the radiator which can track between galleries, cylinders and externally.....depending on whether it's a head gasket issue, cracked head, warped head, corroded head, etc.
i had a similar failure in my mx83 cressida. had a wee bit of oil in the coolant, then eventually the metal ring in the gasket around piston 6 distorted letting water in to the combustion chamber.
needless to say piston 6 was looking nice and clean after its steam bath :/
replacing head gasket isnt that hard, if you are doing it yourself make sure you take pictures of everything you take off so you have reference to put it back together :/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
