  • Replies 14.2k
yeah unfortunately I have to look at it this way as well.
I wanna take the fam to Europe & the States before I do Japan
Same here. I'd love, love, love to return to Japan (lived there for a stint in 1997), but I really want to go to the IOMTT in the UK. And Tracy would love to visit London again.
:D
oh Dan, i agree. This dumbass on facebook that went to my primary school, my god. Constant updates like this:
"do u think thr is one person ur sapost to b with 4 the rest of ur life"
"who r my close frnds"
"bye all gunas watch dvd"
"all u fkers that ses sht to my fam get a life im not hvn a baby got it"
Sad thing is, its only gonna get worse - teachers don't teach grammar the way they used to it seems, and when newspapers employ journalism students who cant use a dictionary or thesaurus, then you know the people reading it are going to pick up the same bad habits.
Check out any article on adelaidenow.com.au for example.... loads of error, and it seems that the editor doesn't edit anymore...
Mind you this was inevitable since we lost the news years ago - having a single newspaper in a city doesn't do anyone any favours.. and for what its worth, the australian seems to have more important articles, rather than be filled with nonsense about what b grade celebrity is doing what. They even dedicated a whole page to Kellie Nestors impending pregnancy - which is nice for the girl but cmon, is that newsworthy?
-D
EDIT - Not in a GTR nigel, but did get a very nice one made up for my old r31 by boss engineering at lonsdale - top work if you're interested in getting a replacement
Nigel what u wanna know? I got a bnr34 nismo 1.5 LSD on it's way for me atm. Will also be going a nismo 1.5 for the front. Some people are also using the quaife front diff but they are around 2k where the nismo front is 1300ish.
I have a collapsed bearing on the drivers side, and its been slipping a fair bit lately. So thinking of upgrading to a aftermarket, because im sick of replacing diffs and drivetrain components on this car and want something stronger!
KAAZ dont make a 1.5 way, where Nismo do, and i think OS Giken do too.
Don't want to spend more than I have to, as I've just been informed that my transfer case requires work now too GRRR
394 defect notices since july last year.....umm i wonder how many of them were "pod filter not secured" kinda defect.....they dont defect the rust buckets out there either.....some nice revenue raising for the govt
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
