  • Replies 14.2k
if you tell ebay they should get in sh*t for it ruby. same with getting friends to bid up the price. but thats harder to clearly show.
and the pic of the 32s tis awesome :)
I've already lodged a complaint report against the seller. He's countered by marking me down as an unpaid buyer. Ebay won't do shit ... this has happened before, and they don't care.
:3some:
Now I gotta source parts for my race bike all over again.
just spent the last hour pulling my drivers door apart to try fix the central locking and the lock.
pulled the lock out and pulled it apart to find half a broken key wedged between the pins
so after about 20 minutes of using tweasers and small screw drivers i finally have a working lock again
woot :)
:D
is he in Sydney...Could go ans sort him out for you....Cause im heaps tough and soo soo scarey :)
So i bled my brakes up this afternoon and from what i can see no air in the system...Still have a spongy pedal! WTF!!
Cars arghhh :)
did you release the handbrake while bleeding the system?
ive done that on a few cars before haha
anyone know of any decent car detailing places down south?
found one in lonsdale but they want me to pay them, for me, to do it there with their stuff lol, i dont think soooooo
just want the outside done, cut and polish and clay bar i think. for a car thats been sitting in a shed for the past 3 years :s
do the correct order?
Yep back left back, back right, front left then front right
is your booster hose on the right way?
Only changed the master mate not the booster
Nope handbreak not on!
Bit of history...I've gone to R32 front calipers on the car, with the standard DR30 master the peddle was spongy but the car stopped well, so i was reading NS.com and some of the lads on there have reported this as well and have fixed it by going to a 32 master as well, so this is what i've done...Bled them up still spongy pedal!
If u guys have some spare time check out this build thread.
http://www.gtr.co.uk/forum/135019-ams-1000...-lots-pics.html
And all the others on there.
love the thought they put into the design process
measure twice cut once sorta thing
I went to school with the guy that owns that joint, good place to deal with.
yeah the guy im dealing with seems like a pretty good dude
i found the engine on ebay complete,
so i thought id give them a buz and see if he had any long motors
they didnt, but he said he would strip it for me and halv the price :thumbsup:
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
