  • Replies 14.2k
sigh.
4 prank calls over about 5 minutes under the pretense of buying the 200.
im all for prank calls, but put some imagination into it, and make sure your mates arent giggling like school girls in the back ground, kills the joke before it even starts.
and surely people must have something better to do on a saturday night than trawl classifieds looking for pranking victims?
nope i dont think so but there is a trick to getting it activated to which Martin showed a customer in which i was there :ermm::P:banana:
not 100% sure if Gavins is the 2010 model that's the only unknown but LC2 is no where near as harsh as original LC
I am pretty sure they killed LC altogether in the US models when series 2 came out .... but yes the Aussie ones shill get a dumbed down 3,000rpm version which is much gentler and doesn't blow the trans.
excited. boat finally brought my container.
tomorrow get to p/up stich mags ($30 pound!)
grex camshafts, spats strut bar, 6-point roll cage
exhaust temp sensor, turbo timer, bride left hand seat rail
bride drivers chair, apexi power intake piping kit
got all the parts for the rb26 buildup in the cupboard now:
hks oil pump, hks step 2 cam springs, n1 water pump, acl race bearings
hks 87mm pistons, attkd rods, arp bolts, arp main head studs
cometic street pro full gasket kit incl 87mm mls head gasket
tomei sump baffle pickup kit, tomei oil gallery orifice, ati harmonic balancer
greddy timing belt, new idler/tensioner, adjustable intake/exhaust cam pulleys
30-row engine oil cooler, oil filter relocation kit, turbo oil cooler
hks split dump pipes, obx tuned-length manifolds, obx front pipe system, decat flex pipe
fitted wilwood superlite forged 4-piston calipers with 324mm drilled rotors up front.
got to install the external fuel pump and fuel surge tank system, then attack the exhaust
and sort out the seats, weld in roll cage and add to it, fill the belt/seat mounts in (eventually rego for 2seater?)
hey blokes looking for an answer to a basic q but just dont want to spend all night looking for it if possiable
mate has a 300zx 31 model vg30 he needs a set of injectors and was told only nismo items will fit due to the fuel rails ok thats fine but what size do nismo items come in? and are all nismo items interchangeable within all nissan stuff ie skyline,silvia,180?
whats the price(reasonable price) on a new set?
price on a 2nd hand set?
thanks guys
Edited by JETURBO
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
