  • Replies 14.2k
i knnow fitting restictors and doing internal mods but shaun said not to worry unless your rebuilding..
i have mines cam baffles and 26 covers which will help..
all built engines i have read in the FI have had this mod done!
What are you doing it for? I have a 26 which are bad for oil problems and i wouldn't even bother with one.
coz mines gonna see some limiter loving come june 19th drift prac!
and im just making a $200 sacrifice to save my engine..
i did read that unless u have a aftermarket oil pump u dont really need to do the external oil drain..
the baffles should be fine with a catch can setup..
Just fill the oil up to the top of the H on the dipstick, That's how i keep my RB's alive on the track.
and its worked so far
from what i saw it wasn't easy track time either and what maybe 8 laps with some drifting on the SAU|sa track day
In other news, "Lost" sucks a fat dick and I'm glad it's over, that ending was... was... there are no words
OOOooooh don't spoil it - I'm just about to finally get around to watching it (just watched the 1 hour 6 season-spanning re-cap episode) ..
Gah! Now I'm stressing that I've wasted the time watching 6 seasons of a tv show :cheers:
I personally thought it was a piece of shit but you're experience may be different. Let me just say this, a certain main plot point in season 6 was TOTALLY useless, the last few minutes of the show totally wipe it out. That and the "ending" was something the creators said from day one would never be the ending
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
