  • Replies 14.2k
i knnow fitting restictors and doing internal mods but shaun said not to worry unless your rebuilding..
i have mines cam baffles and 26 covers which will help..
all built engines i have read in the FI have had this mod done!
What are you doing it for? I have a 26 which are bad for oil problems and i wouldn't even bother with one.
coz mines gonna see some limiter loving come june 19th drift prac!
and im just making a $200 sacrifice to save my engine..
i did read that unless u have a aftermarket oil pump u dont really need to do the external oil drain..
the baffles should be fine with a catch can setup..
Just fill the oil up to the top of the H on the dipstick, That's how i keep my RB's alive on the track.
and its worked so far
from what i saw it wasn't easy track time either and what maybe 8 laps with some drifting on the SAU|sa track day
In other news, "Lost" sucks a fat dick and I'm glad it's over, that ending was... was... there are no words
OOOooooh don't spoil it - I'm just about to finally get around to watching it (just watched the 1 hour 6 season-spanning re-cap episode) ..
Gah! Now I'm stressing that I've wasted the time watching 6 seasons of a tv show :cheers:
I personally thought it was a piece of shit but you're experience may be different. Let me just say this, a certain main plot point in season 6 was TOTALLY useless, the last few minutes of the show totally wipe it out. That and the "ending" was something the creators said from day one would never be the ending
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
