  • Replies 14.2k
lol i got the coin but not using it for another car unfortunetly as my new job will be sending me off shore and around australia and maybe the world so will be getting a house and renting it out
nothing wrong with ca's man, pulls very hard, very healthy and strong and much better then an sr (sounds better too)
Edited by Import S13
.. its running but shes starving for fuel... its killing me..... tomei(whoever makes it) fuel pump isnt doing what it should so looks like ill be getting it back severely detuned.. untill i can free up some more money to go one in tank and twin externals + surge tank... sir dale stirls will be helping me through the fueling journey and and were gonne setup something than can hopefully munge on e85.... i was once told patience is a virtue and im truly learning what that means now.....
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
