  • Replies 14.2k
sorry to hear of your car Carl
i had the same thing happen to me 2 weeks ago in the camry power steering stopped and i couldn't turn, i stopped the car mid way through a corner and turned it back on all was good lucky i was in the back streets
well i just crashed the 32 a lil bit
got out the driveway, and noticed the squealing of cold belts slipping wasnt stopping, so i pulled over and had a look. what i thought was the air-con belt had jumped over one spline and was sitting on an angle. so i thought i would nurse the car around the block and pop it back in the shed....
this belt turned out to be for the power steering pump, and when it went i coasted gracefully into a stobie pole and munched my passenger wing mirror cos i could barely move the fkn steering wheel. it took me 15 min to get the car 1/2 a block then in the driveway to the the round the back. i could have crawled faster using only my tongue.
**** note to self..... remember which is power steering, and which is air-con
had the same thing happen to me mid corner out near lobethal a few weeks ago , except it was a busted line :domokun:
just lost an old reserve mate over in afghanistan
R.I.P Smithy
http://www.adelaidenow.com.au/aussie-soldi...u-1225876776920
RIP To your mate matty
They shall not grow old, as we that are left grow old:
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them.
-D
R.I.P Smithy
my best friends husband was good mates with him and was in his squad as a bomb and amo tech, but clinton went to Vietnam due to personal reasons very sad day for his Family, extended family and Australia
On a different note this had me in tears
check out the badge and the number plate
http://www.carsales.com.au/all-cars/privat...id=128629C972AD
holy f**k, someone post some boobs, quick, this thread is going OT!!
:) Looks like I need to start a tax thread... j/k.
Speaking of tax, with relation to cars, our window identifier codes in one of our programs at work are shown as RBxxx, so you get RB025 for the main screen and RB026 on another one.
I HATE ITUNES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My god why does apple have to make everything so hard? Its easy to put music on but be fcuked if you can get it back off! Another reason i'll never get an iphone
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
