  • Replies 14.2k
The REAL clincher for me is.... iAds I hope this isn't used an abused. Just the thought of a constant stream of advertisements on my phone, ergh, I get enough on the internet. Investors have already thrown $60m at iAds so it's gonna be pushed hard I think. No matter, I'll just get an app to block the ads, oh wait, Apple won't approve of that app will they?
You mean AiDS right!? :wacko:
I hate to be mean because she was a nice lady, but the joke was funny. My mum was on Wheel of Fortune 20 years ago, and met her, said she was really nice to everyone, an awesome person.
But the fact that a joke is "too soon", kinda makes it funnier.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
