  • Replies 14.2k
ive got a usb cable which is that ^
does it HAVE to be firewire to work ?
Has to be Firewire, USB and Firewire are 2 separate communication types. So, yes it DOES need to be Firewire. There is a USB cable that looks similar, but will not work.
so my brand new, less then a week old lap top blue screened on me and when i got it started up again i get this:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 3081
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: 0000000000000000
BCP3: FFFFF88002FD1B48
BCP4: FFFFF88002FD13B0
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
should i be worried? it hasnt happened again but i've only had this thing like 4-5 days.
ahhh ,
will have to go to dick smith tomorrow n get one
does that mean i can upload it using movie maker on my pc?
ahhh ,
Yes, I use my mum's video camera, and use windows movie maker to import and edit the footage, my dyno run that I recorded was done that way. Windows XP, Vista and 7 have it, you may have to download ot for windows 7, still free.
gonna do something about your cooling panel and hood getting all touchy feel while youve got it all off?
Yeah, I'm gonna get onto that and a few other little oddities in the next few days, not like the car is going anywhere
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
