  • Replies 14.2k
tristan still ran 25mm bolt ons with those rims :)
gotta love wide body
I actually had 27mm bolt on spacer to fit the rims on the front and they only just clear the coilovers :D 2.5 deg of camber helps them fit under the guard but no spacers on the rear.
Got the call today to say that Geoservices were pleased with my test results and said my interview was great!
I was offered a job on the spot and start as early as Monday :) sooooooo stoked and soooooo much more money then what I used to earn. Double infact!!
Gotta do helicopter under water escape training in Perth and a week of in house training before they send me off to a rig somewhere in the world!
After my first stint away, when I'm back I'll be looking for an EVO :D
I'm not too sure yet man. I've got my eye on a few cars but ideally it'll be something 'S' chassis so S13 or 180sx mainly because their is epic amount of parts available for these, cheap, and I love the styling of them. Smashed up pig S13/180 is hot lol aswell as a clean streeter with outrageous fitment.
Did it take you a couple of laps to get into the swing of things, like basically not sliding the first few laps?
Be good for the first timers if they let us just lap the track a couple times just to get the feel of the track
this is were i may have gone wrong lol
first time on the track, i went about 130kmh on the handbrake into turn 1 haha
i slowed it down abit till i got the hang of it. still havent tbh though. i want a missle spec 32 or a 180 now as a slide car.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
