  • Replies 14.2k
^^ Looks Good.
Can anyone tell me what size bolts are used for an RB25DET Gearbox, as I am wanting to put my spare block onto my engine stand, but the M10x90 Galvo's I bought from Home Hardware seem to go in about 5mm and then get stuck.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
