$270pw is f**k all, I wish mine was that low, f**k, I know a few people making close to those sorts of repayments on cars
did you buy mate?
or have you been in one a while?
and yes.... i know still haven't had you round for a drink
  • Replies 14.2k
did you buy mate?
Yep, I bought, get the keys on the 15th of July. And I'll have you over before you have me over :P Check your PM's on facebook, I sent you a link
Yeah I DREAM of paying $270pw mortgage repayments .... try nearly triple that. But it is a nearly $1M house, so you have to expect to pay a decent mortgage :rant::D
Shit yeah, would be nice, maybe one day lol
Haha like your avatar Nick .... and where is MY VodkaO? (Or at least a hat)
Had to celebrate, we just won Gold for both rums (white and dark) and with our tequila at The World Spirit Show!
Got a Tequila Blu shot glass for you mate
Congrats mate, no doubt at this rate you will,
barely been home lately, got so much on at the moment between 3 jobs (collecting them at the moment) and family illness
Not good man, best wishes to you :P
I'm not sure on the whole setup but I think you can get adult entry apprenticeships that pay you decent enough money to survive on. Does your missus work too? That would be a big help. My point is, nothing is impossible, difficult yes, impossible no
I just turned 27 and I'm a first year apprentice :P
Thinking about getting into a trade also. Want to work in and around cars as I have no interest in anything else. Narrowed it down to either panel beater or mechanic.
Don't do mechanics. No money in it unless you own a garage that is successful
Yeah I DREAM of paying $270pw mortgage repayments .... try nearly triple that. But it is a nearly $1M house, so you have to expect to pay a decent mortgage :rant: :rant:
toff :P if you ever need any awesome gardern art or insane sandstone, feature urns or water features come see me ill make ur house worth 1.1m hahah
skyline is safely locked away in the back yard under the protection of ryu the malamute yet protected from ryu himself :D had a 10 hour day at work to think about how lucky i am.. cheers for all the wise and constructive comments guys. think ill just remember not to use the gtr for the odd comute, just events and sunday drives. cheers for the advice nigel, doors seem to be in relatively good nick but even i know how to break in with a coat hanger withought damaging anything. small dent in bonnet where the pushed it to its second destination. anyone know how to fix the locking mechanism on the steering wheel?
Hmm, I need a bit of paving done around the house Mark..........any ideas?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
