Ok, I see it in writing, but any more conclusive proof than that? I'm not disputing it, just I've never heard of this before and I'd say if it were true early 26 blocks would be sought after for rebuilds which to my knowledge they aren't. From what I can read it's only a few people saying "yeah, they're better" If a tuning house/Nissan came out with that info, I'd beleive it
  • Replies 14.2k
And to play you at your own game from the same links you posted...
"Though that rumors are spread quite often on the internet no one has actually come forward with any hard proof that these "homologation" blocks existed in production skylines. I have it on good authority though that the N1 block is certainly different from a september/89 build gtr. If rumors are true only the first 500 bnr32's were supposed to have these better casting blocks."
this is true
however ive done enough research to know that in either case, the strength of the block is nowhere near as important as getting a balanced long nose crank with a decent harmonic balancer, H beam forged conrods and forged pistons. i quite like the nitto kit but tbh its overkill for what i will ever use it for
-D
Its all very well for you pseudo mechanics to sit back on the forum and make estimates as to what my engine can and cannot do
I happen to have the estimates confirmed by road and track as well as the guy whos making the turbo
the compression test indicates all cylinders are within 10psi of each other, and having paid as much attention to the rb26 performance thread as you Andrew, I know for a fact that 300kw is not pushing a set of N1's by an stretch of the imagination
i for one will trust the advice of the very mechanic that has worked on the car for the last 3 years, rather than a bunch of armchair tuners who never even looked underneath the hood
incidentally, i have the first series of rb26's from the nissan factory. my vin no is 3129/89. The block is as known to be as strong as an N1.
Theres no f**king way Im going to blow a f**king piston thru the f**king side of the f**king block, and you know why? Cos i spend the f**king money on f**king tuning and never let anything run lean.... case f**king closed....
You guys are like a bunch of italian grandmothers trying to stop their granddaughters from getting some dick in em
-D
Ben you need to calm down or go somewhere else to play.
On your statements of mechanical knowledge, where you putting me in that group as well??
I was involved in engine reconditioning for more than 3/4 of your life and can no doubt teach your boys at Road & Track a few things..........I'll grant you that they would have me in the tuning department.
A block's thickness is totally indicative to a rod spinning a shell or a land cracking......you can blow engines in a bad way without an inspection hole in the side to show for it.
If as you said, your valve timing has been out for a year or 2 and you've hammered it like I've seen thru the Adelaide Hills, your pistons are probably itching to let go as we speak.
Anyway, calm down.....we're only talking car shit between friends.
Spot on, questionable running that sort of boost/power through a motor that has been running incorrectly for god knows how many kilometers of it's life. All we're saying it be careful, if it's a daily, don't run it on knifes edge, you still need to get to work should shit hit the fan
Im quite calm pete, maybe step back for a minute and realize that every post i put down isnt about you.
i know your history, i know u know engines, but to say you can teach a man older than you whos been building engines before you yourself had hair on your nuts its pretty rich. i think u need to step back and take a deep breath.
For your information, I never hammered my car in the hills or otherwise. I dont drive as hard as half of the heroes out there. I dont know whats so abhorrent that I can admit im not a hardcore driver and then everyone assumes i dont do my research. Fact is, I respect my car too much to push it so hard that it gets damaged. Thats why I've spent over $25,000 on the car over the last 3 years. Does that not count as to nursing the fk out of a car?
I really dont know what point you're trying to make. You've totally lost me.
And if anyone thinks I'm running anything on knifes edge simply does not appreciate the dialogue I maintain with my tuner.
Yes the valve timing was out, however it was within a safe tolerance and was running rich to a factor of 11:1 - which is hardly a ratio to worry about
-D
you don't go above 3500rpm ???? are you driving a diesel??? or your nanna to doctors ???
the N1's power curve will move up the RPM range ,making it less then fun in traffic, have you ever driven a honda VTEC below the 4k, like being chained to a house..lol no torque off boost
Ben not saying it won't be fun but after living with a partial tube frame race car on the street for 11 years..... it wears on you, RX7 with 300hp 12a Bridgeport/ alloy flywheel = electric motor , hauled ass but a bit much for a daily. wish I had it now...damn it..lol
and ben running too rich can kill and engine over time too, carbon build up= misfire from hot spots of carbon, broken ring when it dislodges, Pete is trying to say the same as me "think before you waste a buttload of money on a daily driver timebomb"
Just playing devils advocate here... just because you are running proper AFR's, doesn't mean you aren't stressing the engine. I can run my 26 with good AFR's, whack 24 psi though it then hold on. However, it won't last too long either
Guys
We're talking about n1's
they have the same f**king compression wheel as an r33 gtr and and a slightly bigger exhaust turbine than the ceramic version that still fits the 0.48 housing, and it just happens to be metal, meaning u can boost it over 14 psi
these are not rs turbos let alone -5's or high mount single ball busters
farks sake theyre equivalent to -7 2860's
next thing you'll be trying to convince me that the bogeyman is real
and yes mate, i keep the car under 3500 rpm when im driving in traffic, i hardly think accelerating up a dudes arse and then slamming on th brakes is anything to be proud of, and I have a straight pipe exhaust so i try like hell to keep it as quiet as possible
-D
Guys
-D
Meaning you are cramming a measurable more amount of air+fuel down the motors throat, resulting in more power, more stresses and increased wear.
Just saying s'all :)
word man, but geez, ive been reading the rb26 thread on sau for the last 5 yrs man, and i know for a fact that 300kw is not like asking a politician to be honest
they generally benchmark 290 for -7's / n1's on stock 444 injectors and afms. unlike many others, ive done the supporting mods before i got the turbos. i got the nistune. i got the injectors. i got the nismo calibrated afms. soon as i get the turbos themselves, i bolt them up and let shaun at boostworx go nuts
i have full confidence in road and track and boostworx. ive been using r&t for 6 yrs and theyve never made a single mistake, ever. cant say that about any other workshop ive been to.
-D
-D
Is that what your tuner told you?
Your valve timing should never be out, your crank & cams are either in sync or they're not...........what's this safe tolerance business??
Your ignition timing can vary and be within a safe tolerance however.
You can run an overly rich motor (which is also bad) but advance the shit out of your ignition timing and still get a high knock count..........why didn't your boys pick the TDC alignment issue up a year ago?
No disrespect to your tuners Ben, but even a 60 year old mechanic that's been assembling engines since Noah was a boy may not have the same machining or diagnostic experience as maybe a 35 year old with 20 years of engine reconditioning experience.....they each have their own speacial talents and could no doubt teach each other new tricks of the trade.
By the way, I'm only a smidge over 35 :)
cant reply to u technically to u pete because im am a lowly pc technician who obviously knows f**k all about engines
and if ur that shit hot at machining then i want you to machine my fkn engine in 2012.
put it this way, im getting the power back at LOWER boost than was required before
ultimately i cant say how its going to go either way, however im getting a full rb26gasket kit, removing me intake plenum and manifolds, rocker covers etc
getting everything powdercoated black except for manifolds which are geting ceramic coated along with the exhaust housing of the new n1's i get next week
i cant see how any damage can be caused for any tune where there is too much fuel. lack of power sure. not like im melting my damn pistons
-D
EDIT - You're under 35? Yeah and I rooted alyssa milano last week. really.
I'm def not and no thanks
Where did I say I was under 35
:) = far from it, LOL
aww
i was hopin u would machine my cylinders
and i could get soem big boobed bitchen to rub u on the head like a buddha statue, for good luck
but hey, if ur too busy to let women rub ur head then bugger ya, do what ya want, etc
-D
edit - http://www.handlebars.com.au/sponsors.asp
as far as im concerned, if its good enuff for charlie, its good enuff for me
I understand everything you are saying Ben, but for R&T to say your motor will be fine with the upgraded power level on the basis of a leak-down test is pretty poor. You have only had the car for 3 of its 20 years, so god only knows what maintenance schedule was had before you got it. Unless they have opened the engine and inspected the internal components I just can't understand how they can guarantee you are not going to spin a bearing, crack a ring-land or whatever else.
But it sounds like you are on the right path putting in all new gaskets etc,, so at least they can have a partial visual inspection of your engine internal before the N1s go on.
And on the topic of you 'going easy on while it' while it was mechanically impaired (just in case you forgot), you gave the 32 a fair hiding on the way to Kadina last year and Balgowan also - I saw more than a fair plume of black smoke behind you and you will remember being destroyed by an n/a V35 at one point :) .... which I now understand now you have revealed your power level issues.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
