Does anyone know of any 32 gtst's for sale cheap.
The motor and trans are going to be binned so wouldn't mind a rolling shell, or a cheap auto one but want the turbo brakes etc.
Need it for a project, would like a black one but wont be to picky for the right one :down:
Edited by Import S13
  • Replies 14.2k
tangles is selling one with an rb26 already in it, cheap too
-D
Edit - looks like he beat me to it
matt, what happened?
idler pulley collapsed saturday night driving thru town
a bit more investigation showed that i paid for a timing belt to be changed last year, and it never got done (as a previous service to replace a front crankshaft seal delivered a rusted on harmonic balancer and 2 broken pullers trying to get it off LOL). needless to say im less than impressed and hunting thru my old receipts to see what i actually paid for
Oh what, no plug Matty? :down:
Very lucky today Matty. Could have been a whole lot worse. Glad we got it sorted though!
RD28 power!
I gave you a plug.....Now simo and anth know your nickname :) ROFL
Definitely feel lucky......and definitely know where to go now :P
I gave you a plug.....Now simo and anth know your nickname :down: ROFL
Definitely feel lucky......and definitely know where to go now :)
Yeah, i got called that non stop since you left...carnt!
Pete (Sled)
CE28N come in 19x10.5 or 19x9.5. Offsets +12 and +25 in the 10.5 wide. +12, +22, +25, +36 and +45 in 9.5 wide
Roughly 84-86,000 yen each.
Doesnt say anything about a black colour tho :down:
does anyone have a massive movie collection on their computers/hard drives?
upgraded my hard drive to a 1.5 terrabyte and need to fill it up :ninja:
yer i got movies. tv shows, mp3s
pm me if u wanna bring a usb hdd over
i wont be opening my pc up for u tho ;P
not that i cant, i just cant be stuffed
-D
245GB of TV series and 342GB of movies.... there goes 1/3 of your HDD lol
Maybe :ermm::ninja:
legally of course ive got some movies not hunderds but i dont have much in the way of tv shows
massive fap collection
ill be away on oil rigs with a bunch of dudes for weeks at a time.
fap collection would be sweet haha
-D
its external mang :D
