  • Replies 14.2k
Trying to make a choice on cam gears. Basically comes down to what colour I like.. Hmmmm... Purple HKS or blue and red TOMEI..
speak to isc and get one of each for half the price
blue for intake, red for exhaust ;D
=D
HAPPY BIRTHDAY!
i concur :wub: :wub: :wub:
I don't really celebrate birthdays either .. just feels so weird here alone, today more-so .. still getting used to the house being since my ex left.
yeah celebrating is so 80's
Growly Custom Machining made these for CA18 not sure if he does RB ones
http://www.growly.com.au/products.html
The fiance said HKS, because its pretty.
*agreed* .. it's so pretty & shiny compared to the others :wub:
Bah, you're making me feel old :wub:
Next I'll be grumbling about 'bloody kids' and yelling 'get off my lawn' ...
I was going to go with Nitto cam gears simply because they listed the exact grade of their billet steel which was very high quality - the shop didnt have them in stock and i needed camgears so i went with a set of isc, which are effectively the same (5 point tension screws as opposed to 3 or 4)
why pay $600 when the ISC for $200 are just as good (if not better imho)
that said, id still go nitto if i was pulling 600+ hp but for my needs, isc is win
-D
-D
Do ISC cam gears work okay on all R34 Neo? Doesn't say anything on their site...
I know you have to get a specific one for NVCS:
http://www.kudosmotorsports.com/catalog/tr...nvcs-p-661.html
vs
http://www.kudosmotorsports.com/catalog/tr...nvcs-p-114.html
vs
that im not sure of
however given i have an rb26, i know the parts are a little more common than say, i 1jz... $200 for a pair of 26 camgears is a good buy - most 'name' brands double it. nitto are still cheap ($220) but they list the exact specs of their billet steel - which i like)
in either case- isc camgears have done the job for me on my rb26 so kudos to isc
-D
I'll be using these, AL7075-T6 Billet Aluminum
they should be ok,
will be going on a stock 1997 R33 GTR. Im picking it up on monday miday
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
once back on wednesday I will get plates/rego, and take my time to work on it.
throw in my stagea saas seat 'cause of the extra long seat rail and put the gtr seat into the stag.
10mm spaces, 50mm long gtr wheel studs, my 17x7.5 mags with brand new ku36 tyres will go on, and the stag will take the gtr wheels.
I NEED to sell the track car for what I got it for (7k with roll cage, stock rb26 engine) and will ready the stagea for sale.
new Gates racing belt, idler, etc, hks oil pump, n1 water pump, 87mm mls cometic head gasket, full nissan gasket set, arp head studs, z32 afms, apexi hardpipe intake
ati harmonic balancer, arp studs, tomei sump baffle, 555cc siemens, yellow jackets, p-fc, tuned length manifolds, hks split dump pipes, dual 3" to 3.5" front pipe
then hold onto the hks cam springs and greddy camshafts, hks pistons/rods for later.
then sell whatever is left and buy pair 2530 turbo's & some new shocks and rip skids
really excited about owning my dream car! everything is good here now, so onwards and upwards !!!! :wub:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
