  • Replies 14.2k
Seeing shit like that really makes me think twice about getting serious in the drift scene. I know the atmosphere between drivers at prac days etc is alot better rather then the G1 comps. Rather pathetic.
dont laugh, hes serious.....
too many people take it seriously,
they get all mark skaife VS russell ingall n shit
your meant to have a light and funny personality in drift, i can think
of a few ''DA'' drivers that are arrogant cvnts.
Spot on there Craig, I would list a few however being a moderator I don't think it's in my best interests. One stands out in particular as being an arrogant, self centered f**kwit. And a thief and liar to boot...
Sad state of affairs the SA drift scene at the moment. Ruled by a few who think they are more important than anyone else then spit shit when things don't go their way
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
