  • Replies 14.2k
man... that shit with monkhouse... what the f**k? ive seen children with better controlled tempers (and better constructed insults). shit like that needs to stop, drift is meant to be fun, so why cant flamin mongrels like that just stfu and keep drifting fun?
r34 owners - 100k kit is on special: http://www.kudosmotorsports.com/catalog/ni...25det-p-91.html
edit - not even on sale, permanently reduced!
no excuses for track day now
Craig did you order one for your missus :/
Dion, Fabs - clutches have been delayed due to adding to the order will hopefully be here friday or monday
Haven't seen the FB link cos I don't have Facebook anymore, but I'm guessing it's usual DA shit involving a bunch of faggots having a cry.
I saw all the ns.com comments before they were deleted... bunch of f**king tools. I love how half of them say they can be judges because they've watched drift for years then others come in and say "No, you cannot be a judge. I'm better than you" sort of attitude.
And what's this talk of drugs and alcohol on the track now? Who's racking up lines off their rear spoiler and doing skids?!?!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
