That S13 is good man,
You will have to spend a fair bit of coin on getting it to slide really well however given its a straight swap for the R31 I'd say thats pretty decent deal for yourself man.
Bullshit, all you need in an S13 is a set of coils, a mech diff and a race seat and you can bust fat skids all day long if you know how to steer. F*ck look at my shit heap, it's got half assed sus and a stock viscous diff and I can still chuck it around in 3rd and link shit.
If you're spending bulk cash on an S13 and still having trouble you need more practice :(
  • Replies 14.2k
If you're spending bulk cash on an S13 and still having trouble you need more practice :D
Yeah but your skid skills are fkn hecktik man :( haha
there is no way I can justify $3k on rims
My rims cost $2200... each. That's $8800 worth of rims + delivery + tyres. Luckily the former owner paid for them and then Shannons when I damaged two of them.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
