  • Replies 14.2k
get the sherrifs to break the guys arm? theyre usually pretty obliging :D
-D
id rather sort em out at the counter than having to get the sherrifs to put them in a kung fu grip and boot em out the door.... just makes them angrier for nextr time.
must say its pretty entertaining seeing a massive biker getting taken down, and start screaming like an 8 year old girl with a grazed knee at the hands of a small asian sherrif though
think i found my new hangout when im bored !
How's this.
Brother was driving his n14 pulsar last night. Went through a deep puddle of water and got into his airbox into the engine and blew the motor. One piston is sitting higher then the others and there's a bent conrod. Took the plugs out and u rock the engine and can see water in cylinder 3.
Insurance covers it tho. Damm sr20's
How's this.
Hydrolock, it happens. Luckily his insurance covers him, always wondered about that
That sounds a bit weird to me. The airbox has a hole on the side for intake, and the box is pretty deep - so it should easily be able to drain out or at worst sit at the bottom. The N14 airbox works opposite to skyline one too - with air coming in the bottom and into the engine through the filter at the top, so I would have thought it would be pretty hard to get hydrolock?
Never had any issues in my N14 - it used to run a pod, gone back to the panel. I drove it through a semi-flood in Melbourne a few years ago when was a foot of water going across the highway - handled it perfectly (was using a pod filter back then).
how do i find the correct KNURL diamater for extended nissan wheel studs, M12x1.25 to suit C34 Stagea ?
I bought 20 "Ichiba-brand" 50mm long studs, came with 13.75 knurl - wont fit
Now ordered 20 more with 12.75 knurl, got to wait another 3 weeks till they arrive to see if they fit.
getting to be too expensive to keep "guessing" the size.
Ive measured a used one today from the rear and it seems to be around 12.5mm knurl diameter....... Im hoping its similar to the ones Ive reordered just now 'cause they are 13yrs old & used?
confused :P
confused :P
hey mate: try Jap Import Spares. they sell 10 studs for $40 and we bashed them straight into the drift car
thanks
Ive paid for this second set already, $100 del.
if these dont work will definately try J.I.S. - cheers
oh, I torque them on with a nut rather than bash them on.
got to grab a nut to undo the wheel hub bolt on rear LHS - cant insert new studs due to the parkbrake setup. nut must be 34 or 36mm !!
now I need to see what nissans use 13.75mm knurl - possibly GTR/navara/patrol/"insert Nissan model here"
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
