  • Replies 14.2k
My arms hurt big time lol.
* washed car with gel
* shammy it all
* Meguairs scratch 2.0
* Meguairs NXT Generation Tech Wax 2.0 Paste
* Buffed it by hand
Total Time 3 hours. Tomorrow i have to work on the interior and wheels.
Hey anyone know much about bikes here (possibly ruby, although im talking lil stuff around bikes here)
im planning on getting my mate a pit bike trial bike thingo to use on his farm. doesn’t need to be fast just aslong as it go's and we only light weights so doesn’t need any power.
was looking at possibly one of these but not really sure just yet.
http://cgi.ebay.com.au/125CC-TDR-ALLOY-PIT...=item1e5d39f68a
any bought any of them?
What is the reason for only looking at Duel Solenoid EBC's?
Turbosmart E-Boost 2 would be my choice (infact i bought one a few months to replace my DSBC) but they aren't duel solenoid and they don't need to be.
Edited by D_Stirls
Looked into E boost 2, but at near on $1,000 I'd rather a cheaper option that does exactly the same job.
I don't know much about EBC's, but from my understanding the duel solenoid is better for controlling and holding the boost. Last thing I want is it spiking or dropping off later in the rev range.
you can get them for around $680.
I paid $350 but it was second hand.
EDIT!!
Here's one that's $700
http://cgi.ebay.com.au/TURBOSMART-e-BOOST2...=item2c5637a2a2
Just trying to get some opinions on what others are using. Still need a place to mount it where I can see it ( Want to use it as a boost gauge as I don't want to use the standard GTR one)
I just bought one and broke it in yesterday Dan! It is awesome value for money, and one of the best larger pitbikes for the price.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
Cant recommend Cob & Co enough, awesome contact from seller, quick postage, cheap but good bikes, and comes shipped in a sturdy metal frame to prevent breakage
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
