I WOULD JUST LIKE TO SAY I HAVE SOLD MY COMMODORE VT 50L (PIG) AND HAVE ONE OF THE MOST FUN AND CRUZY RIDES I HAVE DRIVEN ........143.6 kw 15PSI r32 93 gt and i tell u it didnt take me long to wack my plates on with proud so hello to all and i hope u guys can tell me more about tha r32 i mean ive owned big hp commos - vl turbos and know of the convertions and twin turbo v8s but i would like to hear your veiw on the r32 motor
spotted SHRUGZ about 7 cars down from my car a second ago :P (dude she needs a wash! :D)
Damn it's sooo nice outside. I nearly got in my car, started her up, and left. Would've driven up the coast....
wil..
and yea.. car really needs a wash... actually front bar and bonnet need respray also cos of stone chips and gutters... make that.. the whole car needs a respray if you include the dents from trolleys from taking the damn woman shopping
used to see 321 GO around castle hill, now mum sees it heaps in burwood
Used to work in c/hill but now in ashfield. Let me know what ur mum looks like so I can wave next time :P
Car is almost sold now but will still be seen round the c/hill area.
SPOTTED : silver r33 fill up in da Shell servo on penno hill rd. Looked like a veilside kit.. white plates.. n sunroof
12:30pm... guy was wearing white shirt and jeans.. looked nice from the teletech window on level 12.
had a red 180 behind it too
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
