gtrrrr is a grey/black 32 gtr.never seen it before.looked very nice
gracer is a purple r33 gtr(gts4 conversion) 478rwkw beast as seen on the cover of zoom competition special 2002
correction..... make that 510 at all 4 :D :D :D :D :D did you see the 200SX with it???
Yeah, did you just take the springs out on saturday night man? we where displaying the zelios magna wagon with R34 frontbar etc.... and there was a HUGE difference in height with your car when we came in sunday morning lol!
Naah my car was not on Dyno TEAMSHADOW ...I wanted to put it in the show but it was too late for the entry....I didn't see the good R34 there except Autostyle guy white GTR who modified my car as well and he asked to put my car there though....I raced Honda Type R when it was going to Dyno on Saturday and i beat him ....
as per the above scanned image, its got twin TD06-20G's on it, the thing is a god damn animal and Peter aint scared of driving it anywhere :):P It absolutely pissed down with rain yesterday afternoon and Peter didnt care one little bit :D :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
