this morning on the way to work spotted tough R34 silver with black rims driving down King Georges rd at Hurstville driving towards Homebush. Not sure if it was GTR but did look and sounded like the goods. I felt so litle in my 32 gtst looking at him driving past. :D:w00t:
spotted SL32 something in artarmon in front of station on tuesday afternoon.. black R32 gtst
w00t that was me
you were in the purple 32?
i was shecking out the paint job and didnt even think to wave haha.. I was half asleep at the time..
this morning on the way to work spotted tough R34 silver with black rims driving down King Georges rd at Hurstville driving towards Homebush. Not sure if it was GTR but did look and sounded like the goods. I felt so litle in my 32 gtst looking at him driving past. :P;)
thanks mate im pretty sure it was me in a rush to get home to bed after a long night shift ! c u round...
Spotted a black r33 gtst with massive dinner plate chromies and the typical "for sale" on the back window on the great western highway in st marys full of lebbos staring at me so i gave them a wave and got a finger and a mouthful of abuse back, plates ATL - 5** if your on here your a tool.
Mate can I ask you a question nothing to do with your post. I want to know what turbo you're running in your R32 and when /or how often you run 13 or 17 PSI boost. I'm at the stage where to go next having stock turbo and running 12-13 PSI producing 145 rwkw at under half a load.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
