Hey, my factory passenger side carbon fibre copy vinyl is sun damaged, can anyone recommend a good seller of a replacement vinyl that will have a high UV tolerance?
A mate bought some off ebay, which turned red within a week, not keen on going down that road.
So, refer quality products, time tested or with a guarantee please.
thanks guys.
https://www.sau.com.au/forums/topic/291969-b-pillar-trim/
  • 5 months later...
Aw shucks Nato, since October, with my new reading skills, I've now gotten to the second paragraph of your 1st post...
After the overwhelming number of responses with conflicting information, I rang my local friendly signwriter, got him to have a look at the car, and bought some vinyl that he recommended.
...and now ^^^ you've given me more to peruse ???
lol
(PS. yes, I used a signwriter to do the advertising on my rear fin - part of it is in red too. 3 years old now. still perfect)
https://www.sau.com.au/forums/topic/291969-b-pillar-trim/#findComment-5148813
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
