Fs: R33 Gtst Rims + Lots Of Stock Parts.
Hey guys i have a lot of left over parts from my gtst laying round i want to sell. (Prefer pick up) but will post some items.
R33 Gtst Rims 16"x 7 set of 4 (tyres are shot)but will come with the rims
Price $220 (pick up only) good for s spare set of rims.
Genuine Nissan skyline strut brace for R33 gtst
Price $120+postage
R33 RB25det series 1 standard nissan coilpacks
(not sure if they are all good as i replaced them with newer splitfires)
Price $100+post
R33 gtst stock suspension
Price $120
R33 gtst Stock dump pipe and front pipe
Front pipe $40 + Postage
Dump pipe $30 + postage
RB25det stock intercooler
Price $40
R33 Series 2 Indicator stalk
Price: $35 + postage
RE: About the coilpacks, they came out of a series 1.5 1995 MODEL.
THEY DID NOT HAVE A SEPARATE IGNITOR PACK ON THE REAR OF THE SPARK PLUG COVER LIKE GTR'S DO, SO IM GUESSING THEY MIGHT BE SERIES 2.
CHEERS
DAZ
Price $120+postage
Price $100+post
Price $120
Price $40
hey man interested in the wheels, can u contact me on 0401165479 cheers
Hi bud im after some parts for my skyline if you got them, I need drivers side Blinker on the guard, indicator switch on the steering column, (series 2) and also I need the surround on the window switch on the drivers side door, Im in sydney too how much for these items, Also if you got a good clean radiator shroud I might take that too cheers, 0422992242
hey mate, as my ad shows the pics u see is all i have for sale, i had a series 2 indicator stalk for R33 gtst, but it has since sold, i still have the rest up for grabs if your keen on anything else let me know.
Cheers
Darren
  • 4 weeks later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
