Hi guys,
im about to organise a group buy on carbon fibre radiator air guide/panels to suit R33 GTST & R34 GTR (most likely can fit GTT with minor modding).
just gauging if theres any interest in these panels?
prices will be around $70-$80 + post, if there is interest, i will create a group buy thread.
i will be getting these from a carbon fibre/bodykit manufacturer in Hong Kong.
Mods, if this is in the wrong section, please pm me & move to the correct section.
Cheers.
https://www.sau.com.au/forums/topic/292371-cf-radiator-air-guides/
very interested BUT only if its the full length ones that go from one side of the radiator support to the other side :D
Hi mate,
sorry its not the one that goes from one side to the other.
I've posted a pic from the supplier above.
group buy link posted here;
http://www.skylinesaustralia.com/forums/Ca...ne-t292380.html
Cheers
