dont really wanna muck around making a GTR one fit my GTT
if you can get one for GTT thats a direct fit with the stock front bar (not the aero bars) im in
Hey guys, as for R33, i wont be getting them in as S1 & S2 are different and will cause problems.
The supplier cant confirm whether its for S1/S2 :P
Guys with R34 GTR, pm if interested.
Have them for S15 also.
need 5 of each.
Cheers
The supplier cant confirm whether its for S1/S2 :(
Guys with R34 GTR, pm if interested.Have them for S15 also.need 5 of each.Cheers
:wave: Whats happening with the R34GTT ones--??
hey guys,
the R34 GTR ones wont fit the GTT as the middle of the front bar and hinge support is different.
At this stage im going to have to close the group buy as there isn't enough interest at this stage and i will re-open again 1st or 2nd month of 2010 and hopefully get some more interest in them.
i will pm all those iinterested in the R34 GTR one next year.
thank you for your interest.
i have asked the supplier to make some GTT ones but they require a sample first so they can copy in carbon.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
