For sale
1991 r32 gts-t
body has type m skirts gtr grill gtr front bar and rear spolier
cabon fibre vented bonnet tow hooks
wheels standard with bridge stone potenzas semislicks can do a deal with a set of 18's as pictured
nismo body stripe .
drive line
6 puk button clutch locked diff , tomei short shift , reco gearbox apexi coil overs dba slotted rotors front
red stuff ebc pds new rear pads and rotors , drift lock steering spacers , new front camber arms
Engine
rb 20 det high mount maifold t70 turbo new braidedlines custom made exhast with hks super drager exhaust ,
38 mm tial waste gate with screamer pipe garret turbo blanket . new hks oil cap , new yellow stuff coil packs ,custom made cooler pipes turbo smart bov , mspec catch tank (2l) trustpod filter gates racing timing belt , machined fly wheel new rear main . head has been recoed including valve reface and head pressue check and skim has 3 layer cometic steel head gasket ,boost contoller ,walbro fuel pump , power steering cooler ,3 remote battery kill switchs ecu has been rechiped
car
has momo race seat with just jap rails , oil pressure ,water temp ,boost guages tacho with shift light
newbigger oil pressue warning light ,new momo steering wheel deep dish front and rear nismo strut braces
helmet net and window net , drift button alloy pedal covers new h/brake and gear boot covers bee*r rev limiter front mount cooler full weld in roll age cams spec cage cost 4 grand its a awesome cage
probly forotten heap whole car was built from its shell car is not reg as just finnished it has done one hill climb since done selling due to not enough time to use as builing a house car is very quick and a weapon to drive
15 000 ono
https://www.sau.com.au/forums/topic/292616-r32-track-or-tuf-streeter/
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
