Lately the leather gear boot off my gear stick started getting loose from my console area. I decided to take it off and either fix it up or replace it.
When I did i removed it, I saw that the metal "housing" (for lack of a better word that I can think of) where the gearstick sits in, was rusted over.
Now I know this area is not going to be seen by anyone, but RUST=plague in my mind.
I've thought about sanding off the rust and applying a rust-proof primer.... but going nuts with a grey primer INSIDE my car seems very idiotic, considering the vapours will probably permanently make my windscreen grey.
What would be a more logical solution? What about that WD-40 stuff? Wondering if I can simply "Clean-off" most of the rust.
Ideas please..........
Edited by DriftinThruLife
https://www.sau.com.au/forums/topic/292715-rust-under-gear-boot-solution/
there this stuff u can get cant remember the name of it.. its like a rust converter should clean it up good if its surface rust.... then some fish oil or rust proof paint to keep it from rusting again....
Edited by rgr34
the thing you are talking about, is it a ring with 4 bolts (1 in each corner) with a rubber piece in the middle? if so, i have owned 2 imports and both of them were rusty. i have also seen this piece on a few mates imports and they have all had rust on them too. i wouldn't be too concerned about it spreading, but painting it with a rust kill type product certainly wouldn't hurt.
Yep that's right! the ring with the screws in each corner with the rubber piece in the middle. I'm not sure why the tighta**es down down at the Nissan factory didn't bother rust-proofing this piece, when it's clearly been happening in previous models. I also had the rust problem with a previous Skyline, but as that car wasn't that expensive to begin with, I wasn't too concerned. However I only recently got this one, and seeing the rust is kinda like seeing needle-tracks on a loved-one's arm.
So the verdict is, get rid of the surface rust with some sort of rust convertor (as opposed to just sanding it off)... and then use a paintbrush or similar to treat it with a rust-proof/Killrust etc to prevent future rust. I think those ideas are awesome. Thanks heaps people!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
