Hi All,
I have a 1997 skyline GTSt with a bit of a shudder. The shudder occurs at low speed on full lock, ie: when I am reversing out of a car park (and turning at the same time) or doing a Uturn.
I dont have an "A-LSD" light on my dash, so I assume that I don't have an Active LSD which was an option on GTSts.
I have read that LSDs can give shuddering if there is the wrong kind of fluid in them, although I think that this diagnosis applies to mechnical LSDs.
From my internet research I wasnt very successful in finding a problem description which related to Viscous LSDs specifically.
It is highly likely that my car has not had the usual maintenance done on it. However, since the Viscous LSD unit is sealed, what would my diagnostic / maintenance steps be?
Would it help to replace the diff oil in this case, or am I up for a job to replace the LSD altogether.. or are there other explanations other than the LSD being at fault ?
Thanks in advance for the advice..
https://www.sau.com.au/forums/topic/292737-lsd-shudder-advice-please/
sounds like you could have a mechanical LSD..its not hard to remove the whole diff if you want to check.
or its easy enough to change out the oil and put a thicker oil in with some additives to try and stop the noise.
worked for me.!
worked for me.!
i also have this problem in my s13 but no solution as yet :happy:
  • 7 months later...
Old topic but I've been busting my brains trying to figure why my car does this too!! Have just realized that full locks, reverse parallel parking etc is fine whenthe car is cold, but after driving for a while tight turns are hard and sounds like the rear wheels re dragging across the road. Could the rear diff have the wrong oil ?? Any info onthis would be great as I wAnt to fix it asap!
could be the wrong oil. stick in some ls90 and some lsd friction modifier. penrite do a 100ml bottle of it that auto one sell here in bunbury so a auto parts store near you may stock it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
