Hey
Ive seen on the internet that the engine power ratings on the R34s with the Neo Straight six's are quiet impressive...
Ive seen 2L neos advertised but havnt read about them...
The 2.5L Non Turbo producing 200kW
2.5L Turbo producing 206kW (same as 2.6L Twin Turbo but less torque).
Ive read this on the internet a few times..
Just making sure its correct? And also what does the 2L engine produce seeing as some R34s have them (so ppl advertise)??
https://www.sau.com.au/forums/topic/29277-skyline-r34/
I read it in errr... a site lol
How come the neo engines are so much more powerful??
Not that im complaining! :)
Read the N/A was 200kW but a fair bit less in torque...
206kW is the legal limit in Japan for stock engines im guessin right..?
Because all major engines STOCK from diff makes etc 206kW.
I cant wait to get an R34!!! Be waitin for a few years tho... :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599882
The neos are also in the Nissan Laurel.
Well the rb25det Neo has different ignition timing ( more advanced VVT system). I guess thats how it got some of its extra power.
All the Neo Motors use whats called a Lean-burn System. Hence ( low fuel consumption )
I found out that there is a 2L neo. It delivers maximum power of 155HP. which really isnt much. I suppose its pretty good for an NA 2L
It would have cost nissan alot more money getting 200kw out of a 2 litre.
Now you said that the 2.5L Neo "NON" turbo makes 200KW
Then you said the 2.5L Neo "TURBO" makes 206KW. What is the point of the turbocharged motor if they both make the same power??
Nissan could have kept the 2.5L an NA motor and still get GTR power.
Well really the 2.5 NA does not make 200KW, Its 200HP
the Neo RB25DET model makes 206KW (280HP)/6,400 RPM
34.0KG/3,200 RPM
CR = 9:0:1
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599922
The R34 25GT (NEO RB25DE) makes 200PS standard (around 200bhp), not sure KW's. which is slightly more than the RB25DE found in the earlier R32/R33. The engine also has higher torque outputs, and late model R34's have a slight improvement over earlier R34's. AFAIK, R34's were available with either Triptronic Auto boxes (+ / - gear change and steering wheel controls) or a 5sp manual.
On paper the R34 GTT (RB25DET) and the R34 GTR (RB26DETT) put out the same power (280ps), but of course, that's "on paper"...
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599980
>jazza08: Looks like your confusing yourself there dude! :)
Just relax, one question at a time, and "All will be rrrrrrrrrrrrrevealed"... (Thumbwars)
Thanks Dave for that "Gem" :) about the Neo-6 power outputs... seriously, how many mouse clicks did it take to get some official figures? 4? 5?
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599985
Rezz - about 3 or 4!! :):):(
As an aside, most of the people I know of, who drive an R34 with the triptronic box say that don't usually bother with the steering controls...
I personally think Nissan did a very good job in upping the power figures for the R34 range, by tweaking the RB series engines, improving (or adding?) VVT to the NEO engines they managed to boost power/torque by a fair bit...
So that always raises the question - how come the R34 GTR doesn't get VVT and NEO technology?
Dave
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-600056
i'm no expert, but i think that the GTRs actually have a stock output close to 300kw, probably a little less. The only reason that they say it has 206kw is to comply (ON PAPER) with the regulations. And i think that there are no more restrictions in japan for power output, need i say more about the next GTRs power??? again im no expert, so someone correct me if i'm wrong.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-600250
If u even take the GT-T power output as correct, 206kw's, a stock dyno run (148rwkw) shows pretty much 30% power loss thru the drive train, that's 30% not 33%. If u translate this powerloss percentage to GTR's at about 190 - 195rwkw's, making them about 280kw's at the fly.
Now i'm not sure if transferring 70% of the engine power to the wheels is reasonable to assume, but if it is 206kw for the GT-T and 280kw for the GTR sound about right.
Oh and just in case u didn't realise, the GTR engine is 2.6 litres and has 2 turbos, instead of one :cheers: RB26DETT
Tiptronic can be done via the gear stick as well yeah? Or is just steering wheel mounted buttons?
And the "206kw" limit was a "gentlemans agreement" in Japan between the different car manufacturers. But if u look at some of the cars that have been produced, 22B STi's, GTR's, Twin Turbo Supras, etc, they haven't been following it completely. But the agreement is no longer so yeah, time for the Japanese cars to mix it with the Euro boys in terms of power output.
cheers.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601371
You can change gears with a tiptronic on the steering wheel or with the gear stick. I have also heard that most people don't use the buttons on the wheel but I do all the time. I think it's because from the very first day I owned it I used them.
The only problem I have is that if you're booting it you have to press the button about 1000rpm before you want it to actually change gears because the revs climb so quickly.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601595
NEO stands for New Environmental Optimisation or sumfin like that, all it duz is make the emissions from the engine better. The increase in power is from the upgraded ECU that accompanies the engine... don't believe the hype :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601839
Spot on FunkyMonkey - the NEO part of the R34 engines basically means they've tweaked it to produce fewer/cleaner emmisions. However, the R34 engines do benefit from ECU tweaks (and also manifold flow characteristics I've heard) that give it the extra power. Not forgetting improvements in the VVT side of things...
BTW, NEO = Nissan Ecology Orientated performance... :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601987
The gentleman's agreement is just that, an agreement - it's not legally binding. There is a hell of a lot more mutual agreement between companies in japan, as opposed to western nations. That's one of the reasons why you often find that pricing for similar products can be very similar between different companies (ie: intercoolers, etc).
The reason for the kW (or we should say, ps) limit is (apparently) to keep the companies on a level playing field and/or to stop any potential power 'wars'
If you look at the cars that exceed the kW agreement - they tend to not be directly from the big companies (HSV is to holden as Nismo is to nissan).
IIRC, the car with the most power over the advertised 280ps is the toyota supra (though the s8-9 FD rx7 probably has even more if you consider power:weight)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-602108
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
