Hi Guys,
Set of R33 GTR wheels in very good condition. Very hard to find a set of R33 GTR wheels in this condition these days so don't miss out!!
The wheels are a forged wheel, 17 x 9 + 30 and very light
Comes with yokohama advan semi comp tyres but hasnt got much meat left on them.
$1,300
Pick Up Only - Melbourne
PM / CALL /SMS
Paul - 0401 046 623
https://www.sau.com.au/forums/topic/292899-r33-gtr-rims/
Free bump for a nice set of wheels. Try Ebay buddy, I just sold a set for the price your after in worse condition.
Alot of Silvia track guys use them and you should get some decent interest.
https://www.sau.com.au/forums/topic/292899-r33-gtr-rims/#findComment-4910293
Shame they are pickup otherwise on these like a fat kid on a cup cake.
Hi Guys,
$1,300
PM / CALL /SMS
Paul - 0401 046 623
https://www.sau.com.au/forums/topic/292899-r33-gtr-rims/#findComment-4911837
i will not seperate.
I am not looking at sending them if you are interested in getting them freighted, organize a courier to get them from here but i am not shipping them i dont have time.
https://www.sau.com.au/forums/topic/292899-r33-gtr-rims/#findComment-4924237
Hey mate, dont sell em too cheap, im the same as 1 of the other guys, i sold mine for a heap more than that and they were in worse condition.
If i still had a GTR i would buy them, but alas, they wont fit on my statesman or my torana
https://www.sau.com.au/forums/topic/292899-r33-gtr-rims/#findComment-4926626
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
