Anyone had there V dyno tuned in Perth?
Where at?
I'm coming down to Perth on the 1st and 2nd, next month
I havent done mine yet, but i no theres a couple around my area. tokyo motorsports Aka Autoworkshop does Ecu flashes and tuning and then theres C red Tuning which im sure do. but il ring em up and confirm.
hey Paul, what copgy back / aftermarket ECU are u running?? there's a lot of places that dyno tunes in Perth but I think its about who's more familiar tuning the software/ECU that you're running.
I don't have an aftermarket ECU
im confused, so how exactly are they going to dyno tune the car? does the v35 have a reprogrammable ECU? ...or are u just after a dyno readout to see how much power ur car's making?
btw i meant p1ggy back ...wonder why it changes to copgy for some reason?
Edited by fcruz3r
I didn't know you needed an after market ECU to dyno tune.
Well i better get one.
Anyone know any good ones to get?
Cant help u in dat area Paul, as im new to da v35 family.
Although as far as tuning goes, C red tuning in welshpool does it. Guy specialises in skylines too.See a few GTRs parked wen im der.
But yea first need to no wat ECu ur after.
hey paul, i recall from your other posts that you won some V6 dyno shootout. Did you pull that with just bolt on mods and no tuning??
as far as aftermarket ECU's go....i think HKS makes the F-Con for V35's ...but I'm not sure if this is the best out there.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
