o <-----before radar detector
(@) <----- after getting caught with radar detector.
the decision is yours, have a good night :)
TJ, I'm a noob, could you please explain that in laymans terms?
hahaha...
Hmmmm... $3000... thats about 10 x speeding fines of doing 10km's or more over the speed limit... jesus.
https://www.sau.com.au/forums/topic/293083-radar-detectors/#findComment-4894744
dont get it :S
yeah... definately right about that...
not worth the risk, just putting it out there... i've noticed they've put some speed cameras up on EAST link, under a little bridge right near WELLINGTON road both inbound and outbound... sneaky...
Parking tickets are terrible too... copped a $117 fine on the weekend at 11pm... dont park in loading zones... hahaha
https://www.sau.com.au/forums/topic/293083-radar-detectors/#findComment-4894762
i sometimes find myself creeping of the speed limit. these damn stagea's are just so smooth, dont even notice :)
Know the feeling m8!!!!
& yeah it's a gamble to get one(radar dect) ,& where u r located personally NO,NO,NO, but thats my opinion,get a speed alert fitted instead maybe,& get to the track on a regular basis, it helps.
https://www.sau.com.au/forums/topic/293083-radar-detectors/#findComment-4894840
I miss the "protection"...that thing was seriously good
I was looking at one on ebay... $140
seems like a good investment... until you get caught + the $3000... that would hurt the hip pocket... i wonder if they would cancel your licence..
https://www.sau.com.au/forums/topic/293083-radar-detectors/#findComment-4894971
This is a pretty sensitive topic so I cant say much, but basically my recommendation is if you dont know what your doing dont get one. Me an my cousin have both been using RD's for awhile now, first time using one in a place sooooo illegal, there are products I DO recommend but for 140 your not going to get ANYTHING good especially since they will be detected by the cops and you'll get raped.
https://www.sau.com.au/forums/topic/293083-radar-detectors/#findComment-4895048
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
