hey guys,
i have a r32 GTS4 rb20det 5spd. had it for last 4 years and built it from stock to what it is now.
i have been running it rwd for the last 3 years, cause i lost interest in 4wd. when i bought it i thought it would be fun to run 4wd and be able to switch to rwd with a pull of a fuse/switch. anyways. not the real problem at hand.
my clutch is starting to slip, so i thought, instead of just replacing the clutch, rip out the front 4wd gear, diff, driveshafts, etc. and go rwd, allowing me to save weight and sell the front diff and driveshafts.
ive tried selling my car for the last year, no one seems interested, and just get something already rwd. so i though may aswell keep it...
i just wanna know, if anyone else does know, what's involved in rwd'ing the car.
1. is it just a matter of getting a gtst sump and ripping the other stuff out or what?
2. what clutch would i need to be looking for. rb20det gtst or rb20det gts4/gtr style?
cheers in advance,
Billy
https://www.sau.com.au/forums/topic/293424-r32-gts4-to-rwd/
You are aware that the GTS4 runs rwd 90% of the time, only engaging awd when necessary?
As far as I am aware, the sumps are not interchangeable between RWD / AWD models. The suspension probably needs to be replaced, because a GTSt doesn't require a hub that takes a driveshaft. You will need to replace the gearbox with a rwd version. You will need to remove all the ATTESSA gear (if you are into saving weight).
The clutch you need is probably universal to the RB20DET engine itself, not to a GTSt / GTS4.
You will likely have problems selling just a front diff - whoever buys it will then need to source a rear diff with the same ratios.
Maybe no-one is interested in buying the car because the AWD doesn't work.
https://www.sau.com.au/forums/topic/293424-r32-gts4-to-rwd/#findComment-4899030
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
