I'm needing a windscreen in good condition in WA (chips are cool, cracks no thanks)
willing to pay handsomely for it. must be good. and preferably in WA.
Let me know if someone has something 0447 188 408
https://www.sau.com.au/forums/topic/293429-wtb-windscreen-in-wa/
which one, the side windscreen?....... ;)
We calls thems "win-duhz" around here.
I got a call from o'briens just today actually. reckons into the 'thousands' to make a mould for my car, then get windscreens made.
so, basically, what you're both telling me is, the guy doesn't know what the f**k he's talking about? prrooobably should have picked up on it when he said "hmm, i've never heard of a ze-fire-oh". then he lol'd. pretty much put my entire mood into the gutter all day. el douche-o-matic. i'll call perth centre tomorrow and inquire. we have an o'briens agent here so das coo'.
rightey. cheers :P
Edited by Dorigecko
Surely cant be that much? Ring around, tell them all you have 2 Ceffies with f**ked windshields, they can have a crack at getting either one out intact to make a mold and produce 2.
Mine would be easy to get out, no trim, the clips are unbolted, there's no water seal, it's just glued in...so just heat it up and gently tap it out, be carefull with it, and brace it around the outside to prevent it cracking anymore.
OR, ring O'Brien, and tell them to ship 2 in from NSW or Eastern States...after shipping costs it'd be cheaper than 3k like you said.
i stated 'side windscreen' because you didnt state whether it was front or rear.
they dont stock rear windscreens. thats $1500 straight from nissan :) ......... :D.
if its front all they do is ship wat eva is in there warehouse in nsw to your local shop and shipping is free as their just moving stock
Edited by Dan_J
confirmed at o'briens for 400 fitted, green glass. happy happy!!
they had stock in canning vale... WOO!
they reckon they've got a mould over here in WA too. crazy shit.
  • 1 month later...
:) stingey f*ckers quoted me 700 ex-east and two weeks wait when i asked them fools!!! GRRRRRRR.
well, obriens has the mould here in WA. its a very, very good product. very good.
