Victorian Bridge Clearances- Confused And Need Halp
Yes...
NO
3.3 means that the bridge is 3.3 metres at its lowest point.
BUT i have taken a 4.0 truck under a 4.0 bridge, its at your own risk and if it all goes wrong then it REALLY REALLY goes wrong.
http://www.vicroads.vic.gov.au/NR/rdonlyre...0/tr1999024.pdf
There we go - should have checked vicroads first ;)
I will assume that you are saying that you should have checked vic roads first and your not having a go at me.
Edited by W0rp3D
Gee you are one defensive boy lately ;)
Either way i would be highly surprise if a bridge that says 3.3M clearance, actually is 3.3
It would likely be 3.4/3.5 to account for the idiot factor, because lets face it, there are plenty of morons out there.
Or worse case, just drop the tyre pressures down.
I have noticed that, maybe its my time of month :P
No doubt the bridges are not quite as low as they say and no doubt the truck is also not quite as high either (especially if it is a rental, they probably say its higher to account for the idiot factor) but for the odd occasion that the two are right i would rather spend the 5 minutes going the long way round.
unsure if its unladen, asking a question for the old man.
thanks for the replies guys, guess we'll play it safe and go around
Just curious how big is the truck your trying to get under it?
EDIT: Oops didn't notice where you said "3.3H"
For the record, we have just built a pedestrian bridge over the King's way on-ramp from Whiteman Street, near Crown. The clearance indicated on the sign is less than the actual clearance for obvious reasons.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
