I just bought an R32 GTR and I'm looking for some wheels for it that are going to fill the guards completely. I've seen 18x10's and they fill them well but not quiet enough and I was wondering if anyone has got 18x10.5 on their GTR. Been looking for photos and from what I can tell they'll be flush with the guards, but I don't wanna buy wheels for them to sit an inch out of the guards.
Any help?
https://www.sau.com.au/forums/topic/293478-aggressive-fitment-on-r32-gtr/
was going to post those exact pics. Not sure how much trouble he went to getting them to fit properly. I know that car has pretty much the entire ikeya formula catalogue fitted to it lol. I have 18 x 10 +18 on my GTR and the rears are pretty sweet but the front could go another 5mm out.
18 x 10.5 +18 will be my next set of wheels :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
