  • Replies 57
is ur NA turboed now ?
It's so close at the moment I can almost hear the ptshhh.
Just in the final stages of putting it in....everything else is sorted, just need to get the turbo put on, and the mod plate firmly affixed :)
Dan
nice man post up the results when its put in..are u gonna get it dyno'd too??
Yeah when the e-manage gets tuned after the turbo goes on it's getting done on the dyno, so full figures will be available.....
Plus I'll be more than happy to post a step-by-step upgrade thread with almost all the details and info needed for anyone else wanting to go ahead with it.
I'll try and include some more pics like the first one, showing stages :)
Dan
Looking forward to your write up - turbo'ing the RB25DE is an option I've been thinking about for a while now. I'd be very interested to hear how you went about it, any problems, unforseen difficulties etc.
Dan - BTW, I didn't check the part numbers for the injectors, will try and get down to Nissan again in the coming week. I'd imagine they'd be different to the R33's & R32's though (part number wise) but probably not in terms of flow rate...
Hmmm I'll edit this bit...because it seems I was wrong.
Took the car for a bit of a more spirited drive :) seem that the injectors are hitting 100% cycle duty at 5300 rpm.....seems strange that a car company would allow a vehicle to hit its upper limit before the redline?
AFM is sitting pretty at 4.00V
Well looks like I'll be in the market for some injectors...R34 GT-t stockies more than welcome :rofl:
After a bit more playing with the computer...seems that the second the AFM sends out 4.00V, duty cycle climbs dramatically. By reducing the AFM voltage by 7 - 10% over 3000-6500rpm, duty cycle only peaks out at 35% with no detontaion or performance decrease.
Yeah I'm keeping compression at 10:1, running 6Psi I've seen this running fine in cars overseas in more extreme heat than we have. Higher compression means faster spooling :)
yep, i'm only looking at running 6psi of boost. now what exact parts are required? if i can pick up some 2nd hand parts for cheap i'm going to do this. like i said, i don't want to make big power, just want some extra kick. we would need a R33 turbo ecu too right?
yea wat parts would we need to do the conversion
wat ecu would i use on my RB20 i heard that they are reprogrammable or would i be better off getting an RB20DET ecu?
I've got an E-manage in my car to take care of Air/Fuel, not sure on the GTS-t ECU, it may freak out as it's not receiving certain inputs from sensors the N/A wouldn't have.
You'll need the GTS-t injectors to stay safe (got some for sale with offers over $75:) )
GTS-t AFM
Hmmm stock intercooler and plumbing, makes life VERY simple.
Stock exhaust manifold and turbo + dump pipe.
Someone to do your engineering certificate and fit some water and oil lines to the turbo.
Off the top of my head that'll be fine.
I've had many different reports on power output 30-50% increase is very likely...if you use aftermarket parts, you can be looking at near 80% like another guy I know...not a bad figure for 0.5 Bar!
Dan
sounds great dan...can you roughly estimate the overall cost for this?
Parts including E-manage you should allow for $2000 maximum.
Compliance plate $110
2hrs of dyno tuning $??? depending on workshop
A days labour for the turbo fitting.....2 if some sort of nightmare crops up :D
But if you're fairly confident at doing most of the fiddly work...cutting out intercooler pipe holes, replacing injectors, fitting the intercooler, making sure everything fits in general. This will slash the effort for most workshops...and keep money in your pocket.
Most people will tell you just get a turbo model...but if you're like me and have grown attached to your current car it makes perfect sense.
Those of you wanting more than 7Psi, maybe try and source some forged pistons, lower the compression...then you'll be less limited in the boost you can run.
Getting the ECU tuned can have a dramatic effect though, squeezing out those extra Kw's while maintaining a very reliable low-boost setup.
Dan
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
