can some one plz describe the effects a sticky blowoff would have
the car jolts 3 times once after you go to about 20% throttle or off boost i spose after you give it over 1/2 boost or so...
i took the bovs out yesterday and one was slightly sticky to push in and would sometimes close momentarily stopping halfway....
is this my drama with jolting? or it is something eles that needs attendance 2?
https://www.sau.com.au/forums/topic/293678-sticky-blowoff-valve-need-help/
So does it feel like its missing or actually been forced back?!?
Not something as simple as plugs?
U checked them?
its not a miss as its only when u come off boost. i cleaned all the afm traced back the blow off returns and found that one blow off had a sticky shaft inside... so i put it down to that... the plugs were only changed back a bit but could allways do with a check up.clean i spose.
Hmmm.... Well like ur saying, ur coming off boost (shouldnt be missing then) and its doin the jolting!
I just dont see the BOV jolting the car?!?!
Seems like a fuel/air/spark thing normaly!!!
try completely blocking off the BOV's and see if the car still jolts etc....if not then problem solvered but if problem still there then get some second hand BOV's
but to my little knowledge i dont think its the BOV's causing that issue......
Checked none of the hose clamps have come loose and all intake hoses are on nice and tight?
Had something similar a while a go, when backing off at around 70kmh the car would jolt, was just a loose clamp.
this might be dodgy, but i see no harm, take off the bov or leave it on and spray it with CRC or WD40. to loosen it up.
Good sh!t LOL
Duct tape, zippi ties and WD40 fix anything :(
Any luck so far Adam???
Edited by MYCEF3
All ready tried a clean and lube.. it improved movement a bit but still doing it....
Perhaps someone has a spare set of 33 gtr stock or AM BOV's to lend cheff for half a day to see if that rids the issue?
lol its just such a prick coz basicly the whole front bar needs to come off to get to them lol....
tryed lubing it and it didnt do much. if i blocked it... it will just flutter and hopfuly get rid of the jolt... ill also check plugs... but too all the intake out and sused out all the clamps and hoses and no love...
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
