  • Replies 56
hey buddy im after the following stuff if u got pm me back if ur cool with the offer too:
> In-cabin driver-side Fuse box cover.--->$5
> OEM BOV in excellent condition with no leak---->$20
> LHS Mirror (whole lot if in black paint)---->$40
> Stock Turbo in good condition----> $??
> Steering wheel if still in good nic ---->$25
> Handbrake handle if still in good nic---->$5
cant edit first post so i guess i'll chuck some prices up for the main things....all these are ONO as im just making them up
near perfect dash pad with most of the dash plastics $50
decent carpet, just needs a clean $10
complete heater/aircon unit $20
washer and overflow bottles $10
shell has a good drivers side rear quarter $50
good complete passengers side door, door trim is average $150 looks to be sold though
near perfect taillights $50 a side for complete lights
perfect rear bar $50
good boot with wing, wing needs a bit of bog/fibreglass $50
aircon pump $20
front crossmember and rack, crossmember might be bent $30
front 5 stud hubs and uprights $50
good headlining $10
ignition barrel with key $50
stock castor arms $20
rear half of tailshaft $10
stock cooler piping $20
fuel tank with filler, no pump $10
rear cradle with lsd and shafts, no brakes or hubs $150
3-3.5in cat back exhaust, single straight thru muffler $100
stock front shocks with hks lowered springs $50
also have non r33 stuff
pair of S15 stock mags $50
pair of 300zx stock mags $50
both painted black with crappy spray cans, would come off prety easy
full set of 300zx brakes and rear 5 stud hubs
front has: calipers, pads, lines and rotors...took pics but they disappeared
rear has: calipers, pads, lines, rotors, 5 STUD HUBS and handbrake cables
$600
also got some alloy 300zx/GTR rear upright things (what the rear hubs bolt to) $100 just been bead blasted so look like brand new
hey you still got the dash?? if you have it witht he all the plastic center pieces would be good too, PM me ASAPPPP" and i might pick apart some stuff if u still got the dashh!!
cheers
Edited by dnggskyline
heath, sorry mate it had a pod
DarkRyda, you mean the little pop out tray thingo, yeah ive still got it. PM an offer
hey mate still available? can you send me your details so i can send you the money, i Pmed you! cheers.
sorry for the slow replys, still got no modem
dnggskyline, still got everything thats in the dash pics at the start of the thread
Darkryda, PM sent
probably best sending me a txt with what you want as the PM system on here takes too long to write back to everyone in the time i have on the computer
0438023584
cheers
Nick
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
