Hey guys,
got my car defected and i need some parts to get it cleared,
i need all standard parts for a R33 GTR.
I'll be happy with either R32 or R33 Turbos
AFM's with plugs
and std airbox
I'm located in adelaide
Any help is greatly appreciated.
feel free to call me on 0425899545
https://www.sau.com.au/forums/topic/294047-wanting-some-std-gtr-parts/
Hey guys,
AFM's with plugs
and std airbox
hey mate pm sent about AFM's
thanks for the quick response guys,
Turbos and AFM's organised.
still need the standard air box. or if someone in SA is happy to lend me theirs for a couple days.
Peter
almont everything organised,
just need plugs for the AFM's.
if anyone has some that they want to get rid of or know where i can get
some that would be great.
Thanks,
Peter
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
