Hey guys, i recently purchased a N/A r33 GTS for a little under 4k a couple of months ago.
Problems with the car included:
- window motor needed replacing
- passenger seat belt needed adjusting
- squeaky noise when started (so far only on rare occasions :(
Anyways, i lost my license about a week before it arrived, was major bummed, but the law is the law and i have to wait 3 months. BUT! that was 2 months ago and im getting excited as ive been working on the car with the old man.
- window motor is replaced/fixed and operational
- passenger seat belt 100% a ok!
- noise i havn't gotten around to
What i have gotten around to is a brand new body kit! all Top secret, front bar, skirts and rear pods.
i didn't have the penny's to send it away so dad and i decided to "bond" ;) and do it ourselves.
This is what we have achieved so far
https://www.sau.com.au/forums/topic/294560-the-job-so-far/
After purchasing the right paint, im playing to add a set of rims, im tossing up between Apec race 6 in shadow chrome or Apec Iniri Competion in gunmetal. Also the kid before me put these damn stickers on the car, there only small but id rather them gone, just gotta figure out how to get them off without ruining the paint. Im also tossing up whether to use black or silver mesh for the front bar.
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4914382
go the iniri competitions for sure, will suit that colour very well. whereabouts are the stickers and how sticky are they? i forgot what i used but i debadged mine and it came up really nice, just make sure you give the spot a cut and polish after most of the residue is off
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4914453
I'd say black mesh.
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4914783
The stickers located either side near the rear wheel arch and they also put "skyline classic gt" near the side indicators on either side.they are stuck on pretty good, i heard a hair dryer would do the trick.
This is the only picture i have of the side atm, the shot was taking just before i purchased the car,
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4915662
you probably already checked this, and im not sure if this happens on skylines, but the timing belt (or whichever straps around your fan in the engine bay) can squeak on start up if its old and loose. to see if thats the prob, rub some vasaline on it start it up when its cold, and if it doesnt squeak could be the problem. it wont squeak when its warm as heat expands things :P
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4916292
Congrats on the buy mate, sounds like you got a bargain. I wish I could find one that cheap I reckon my dad would buy one he really liked driving my old NA 33.
Heres a quick chop of the wheels to try and help you decide, but remember the wheels might look different on the car in real life.
Kit should look good nice to see something different on a 33 for a change.
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4916346
you probably already checked this, and im not sure if this happens on skylines, but the timing belt (or whichever straps around your fan in the engine bay) can squeak on start up if its old and loose. to see if thats the prob, rub some vasaline on it start it up when its cold, and if it doesnt squeak could be the problem. it wont squeak when its warm as heat expands things :(
It's bes to get rid of the squeaky noise as opposed to covering it up.
Tighten all the fan belts.
If you notice the belts are old - get some new ones.
Hope that helps.
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4917181
Thanks a heap for the photoshop :P , im thinking the iniri wheels more so, i dont want anything to fancy that takes your view away from the actual car lol.
About the noise, the guy i bought it off said it might be a clutch problem but he had never had a mechanic to look at it. The squeaking only happens on start up and on rare occassions, so when it did squeak, i put my foot on the clutch a little, the noise didnt change.Then i put my foot on the accelorator and the squeak noise changed as if i was putting pressure on something. The noise lasts for approx. 8-15 seconds. Not long but is very annoying and obvisouly not good for the car lol.
I have another 2 questions though. The original indicators dont fit the front bar. Just wondering what you guys use as "custom" indicators.
Also during the pre fitting process with the from grille. Its a 400r style grille but when i went to fit it, i noticed there isnt actually anything to attach it to the car/lights. Anyone else had this problem or should i just dump it and find a similliar grille with the fittings.
Thanks.
https://www.sau.com.au/forums/topic/294560-the-job-so-far/#findComment-4918936
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
