  • Replies 60
Dean, What was the 2nd defect for?
All this crap is the reason im getting a 2nd car to drive around in, then i can then spend lots of time working on the car making it illegall and then a small amount of time driving it because i would never drive it in popular places anyway.
SKYLINED yes but not as likely, 9krpm, appologies also - at least you found someone who can tune your ECU.
Out of interest, how is your getting the car complied going? Should approach CAPA and see if they want to finish the developement for approval so they can sell the kits. I have actually been told it costs them in the vacinity of 50K to get one of their setups sorted and approved.
Thanks steve. Don't worry about the thread...it's fun to read what you guys like to share anyway :D
My car just spun the crankshaft bearing yesterday.
I will be doing a major engine upgrade soon, depending on the cost involve. My setup wont be "standard" or ideal for capa anymore. They were keen but were not that keen when I discussed this with them a while ago and it does not seems that convinience for me.
I will try to get compliance via interstate route when my car is back on the road.
You need to ask why it spun the bearing in the first place. Normally with a Honda its got a lot to do with oil surge rather than rod loading. Have this looked into very carefully before going ahead with any rebuild, or it may just happen again
Fortunately PCOTY is still alive and kicking after Mallala :) .... sorry to hear about your beast Dan - that sucks. I take it you got a new supercharger belt and then this happens .... what a damn shame.
9K, Sorry to hear about your probs, your car is a weapon
Fortunately PCOTY is still alive and kicking after Mallala  ....
Hoy hoy, mallala killed mine,. 1 burnt out turbo base gasket, 2 x front brake disks with large cracks and a cracked exhaust manifold!! half decent lap time though maybe? haha :D
Thanks for all the support guys
I think Mallala killed me too. I was contemplating on a couple of good laps with a few easy lap in between. However those porsches distracted me :)
Oil temp went up to 134 C
Drove around for a week with this oil :) because I did not have time to get the oil or change it :cheers: (Now I pay for the consequence :))
Change oil and supercharger belt on Sat. Went to Victor Harbour with the slick tyres. Close to redline in most gears. Found bearing noise when I got there :(
After I got back I found that the car was running on 3 cylinders. Compression still good. Noise from cylinder 2 bottom end.
Engine will come out this weekend for examination. Can any one give me suggestion on who is good at building Honda engines in SA? My cylinders are oval shaped though. This may be a little bit difficult in SA :( I am looking at stroker kits, forge pistons, lower compression, higher boost, bigger injectors etc etc but it looks like a lot of $$$ though :(
BTW What are the use of cylinder sleeves?
It looks like I will be short of $$$ for the AEM. I will have to use the Greddy Emanage. Is there any good tuners for the Emange in SA? Martin can you look after me with this one too ;)?
damn sorry to hear about your S15 John .... that sucks ass .... oh well at least mine survived :D ..... lucky I only did the 3 sessions though I reckon - it certainly is HELL on cars!
By the sounds of it your engine oil turned to water and thus you lost the bearing. I take it you still run the factory fuel economy 5W-30 oil, and that kind of oil will not protect your engine sufficiently once the engine oil temps rocket. You should have been using 40wt minimum! I wouldnt have even driven the car once the oil temps went past 115C!! 134C.. pwoah....
Stuff like Redline with lots of Moly in the oil may have saved your hide. Changing the oil out after mallala would have made no difference if the damage was done. Or as Munro said, you suffered oil surge. Did you check your oil level before you went to VH?
Sorry to hear bro... Good luck with the new engine. I'd hate to think of how much the repair will be....
My friend who had a top end rebuild on a B18C got his done at Formula Honda. Of the mechanics is from japan I believe. He knows what hes doing...
9krpm, dont feel too bad, your not the first to destroy an engine on the track due to oil problems, wont be the last. Expensive lesson though.
Can I suggest you give some thought to an oil cooler before your next attemp to whoop more porshces around mallala?:D
How did you go keeping up by the way?
engine cracked open today
crank bearings ok
cylinder 2's pistons was slapping around for god know reason, cylinder 2 wall badly scratched :P We also found that the spark plugs were very loose. Just hand tighted. Spark plug no 2 was shaved. Damn Honda mechanic!!!!! Mallala did not kill me, SH!T honda mechanic did!!!!!!
-10w30 mobil 1 supersyn oil. busky I had no choice mate :) the 134C was a peak temp, my oil temp was roughly averaged at around 120C. Oil usually break down at 140C
-oil cooler on the shopping list ;) thanks for the reminder steve
Time for rebuild with forged internals, decopressed pistons and more boost :) See you guys on road hopefully not tooooo long :(
Hmmm was it detonation that killed your engine then 9krpm? It seems that way, by the sounds of it. Or your plugs werent cold enough. Shucks. Such a nice engine gone to waste....
I don't think it's detonation
AF has been tuned at 12.5 at the ezhaust tip (this is fairly rich because my car cat is fairly good)
The honda cylinder/piston is ovally shaped as well so normal detonation mark is not applicable to my car (I hope :D)
I think it's the oil :D
Busky, are you back aldready?
Nightcrawler, Out Law in town is having a sale on oil cooler. I am planning to get one and custom order the pipes from Enzed in wingfield
  • 4 weeks later...
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
